Boy, do I need your help here...my 1995 automatic 318i refused to start the other day. It was cold out ( -20 C ), but I drove it to work, then tried to start it at lunch hour. The starter turned over fine, but the engine just wouln't fire. I kept trying, and the battery was getting pretty low to the point of not turning the sarter over. So I tried to get a boost (followed the boosting instructions, as per the driver's manual). The starter would turn over fine, but again the car would not start. I had it towed home.
I got the car into my garage, and plugged in the block heater, and left it over night. The next day, I again tried to start it, and almost got it going, so I used my other car to give the 318 a boost. I got it going, but was only firing on 3 of 4 cylinders. I removed the spark plugs, and cleaned them, they were really black. Then I started the 318 again, still not firing on one cylinder. I kept it running to clean out any carbon, then after a couple of minutes, I see from the open hood, smoke coming off the coil-pack. I stopped the engine, and found that a big hole had been burnt out of the side of the coil-pack where the #2 coil was. I ordered a new coil-pack, got it the next day, installed it and the #2 cylinder is STILL not firing.
I switched the #2 spark plug with #1, STILL not firing on cylinder #2.
I switch the #2 spark plug wire with #1, STILL not firing on cylinder #2.
Then I found a site that showed how to find out the ECM was holding any codes. Turns out that the ECM was holding code 1271, which means
" an open-circuit or ground fault in the ignition wiring has occurred with an ignition coil. Place timing light on the ignition wires and check for a signal. Also check the wires for faults, and check the spark plugs, too. "
There are no other codes present.
This seems an obvious code for my #2 cylinder, but I've already narrowed my search and eliminated the spark plug, and the spark plug wire. I have yet to see if the is any signal being sent to the #2 coil, of the coil-pack, but I can guess that there is none.
Any ideas, before I have the car towed to my mechanic ??
Thanks
Thanks
