Congrats on the car dude!
Modifying a car is really nebulous. Losing restriction in your intake and exhaust will almost always assure you more power. By how much is heavily debated. The 20 HP claimed gained by an intake upgrade is basically BS to sell a product.
There are other factors than your engine that you should upgrade for "power". Your driveline is just as important. Your rear end gear ratio is important for acceleration as well as top end.
I don't believe the engine has any quirks per se. You should really do maintenance before mods. An out of tune modded car will probably be beaten by a stock car that is in tune. Make sure all of your sensors are within spec and working properly. If a sensor goes out to whack you can (in some cases) cause problems down the road. For instance (on a SHO) if the coolant temp sensor goes then you can be running rich. Running rich can destroy your catalayic converters, clogging your exhaust, robbing you of power, and in extreme cases damange the engine.
In either case make sure you change your oil regularly and make sure your service is up to snuff.
![Big Grin [:D] [:D]](/images/smilies/biggrin.png)
