318is rough idle
Hi, I have a problem with idling on my 1993 318is. First a little case history that may help. The rubber bellows in between the throtle assembly and the air intake split a few months ago due to age causing the vehicle to stall all the time and run very rough. When I replaced it the problem improved however now every so often the car will stall when slowing down to stop or pulling up behind a slower moving vehicle on the freeway. The idle seems to be searching in between six hundred and a thousand one revs when I first start the car and also does this when slowing down, except when the revs drop below four hundred the engine dies. A real pain in the butt. The only way that I can drive the car without it stalling is to remove the vacuum line that connects to fuel pressure regulator. I have changed the rocker cover gasket to try and eleviate a possible vacuum leak but to no avail. I also removed and cleaned out the Idle control valve of any carbon build up which negligable anyway. If anyone could help me with this problem it would be great.
BruceM
BruceM
