ABS Light
Gabe4
Seattle
Hey guys, what's going on?
By the way, I'm still having problems with the ABS light. I changed the Break Pad Sensors(thanks BMW! You're right they are a sinch to fix). The onboard computer is telling me everything is alright (the 1-4-4-4 code) but the ABS light still comes on. Could it be an actual knock sensor from the engine or something else I'm over looking. Frustrated in Seattle.
[xx(]
1,035
Maryland
the abs light refers to a failure with the abs system. I could be wrong, but I do not think a knock sensor is even REMOTELY related to the abs system.
If I were you, I would the check the speed sensors on your four corners first(I'm not sure if BMWs have sensors all the way around; I would think they do, but I'm not sure); also, I don't know, but I would think their is an abs diagnostic machine you could hook straight up to your abs system. That would tell you exactly what is wrong with your abs system. I know that Toyota does have that; not sure about BMW though.
If a code of 1444 is coming up, and it says for 1444 "knock sensor" then you probably have two separate problems that need to be addressed. A "knock sensor" is an engine component which (not to be funny) senses when your car is about to 'kncok.' This has nothing to do with braking; at least so I believe.
Good luck.
Sean
