I read somewhere on the net that if you do not have the alarm kit installed, but your clown nose blinks and your lights flash when you lock/unlock the car, that if you install the siren, tilt sensor, and motion sensor that you will not have to get the system reprogrammed because it already is if it does all that (one long f-ing sentence).
I tend to believe this as I have an X5 with the full system and the only difference between the way the two work is the X5 has the siren. Both blink the lights twice when you open and once when you lock. In both the clown nose blinks when locked. The X5 also has the feature of disabling the interior motion sensor with a second press of the lock button within a timeout period. When you do this the light goes steady for a moment then returns to blinking. My 3 even does that.
So what do you all think or know? Has anyone ever done the hardware install with the software apparently already installed?
Cause if mine is already programmed and all I have to do is the install of the hardware, then that would be a big deciding factor for buying the alarm hardware.
Thanks in advance.
Thanks in advance.
![Big Grin [:D] [:D]](/images/smilies/biggrin.png)
![Smile [:)] [:)]](/images/smilies/smile.png)
