Announced at Concorso d'Eleganza Villa d'Este 2008 in Como, Italy. These are actual photos, NOT CG Renderings!!
The BMW M1 Homage blends a wide, aggressive stance with intentionally retro/modern twists on the key visual elements that defined Paul Bracq's original BMW Turbo concept and the Giugiaro-designed M1 homologation special that followed. It is instantly recognizable as an M1, particularly in profile, where the M1 Homage's basic shape clearly mimics that of its forebear. BMW's stylists also incorporated similar nods the particulars of the original, such as the louvered rear window; the badge placement in back; the line extending aft from the side glass; and even the wheel design, which is an exaggerated take on the ones you'll find on the original road car. Poring over the details of the Homage is akin to going on an Easter Egg hunt.
The greatest departure is seen in front, where BMW has given the M1 Homage a sinister, imposing face. Naturally, BMW's prominent double-kidney grille is front and center. Its joined by outboard intakes and a trapezoidal lower opening designed to swallow and direct air for both cooling purposes and aerodynamic effect. The car's four round headlights lurk behind thin slits in the front fascia, remaining essentially invisible until they're illuminated -- a tip of the cap to the hideaway nature of the classic M1's flip-up lamps.
