Brake lights stuffed
arcon
19
Auckland, New Zealand
i just noticed tonight 2 of 3 of my brake lights don't work (right and top/mid above the rear seat-shelf). 1996 318is 4-door sedan...
i've had this car for 4 months and its been great except for a few minor electrical issues, and the battery was replaced about a month ago. i have no idea if my brake lights have been faulty the whole time... but surely someone would have noticed...
i think its pretty unlikely that both bulbs are dead.... is it likely to be a switch or wiring issue...? if so anyone know what sort of cost i'm looking at...?
You may be able to fix this yourself. The contacts for the bulbs tend to get corroded/oxidized/dirty. Just cleaning the contacts, or replacing the bulbs usually takes care of it.
For the tail light, open the trunk and look behind the tail light. there is a plastic panel you can remove with a twist of a knob. The bulbs are then located right behind this panel, and they also just twist/pull out. The rear deck light is also accessible directly inside the trunk from underneath the light.
Use a pencil eraser to clean the contacts, and/or replace the bulb.
A shop might charge you up to US$10 - $15 per bulb to do this. The bulbs cost just a few dollars at an auto parts store.
arcon
19
i took it to a local auto-electric i use, they replaced with center bulb for 5 bucks :) the right light bulb had come loose, and the previous owner had jammed some paper in there to fix it :/ it works inermitantly.... so they are going to have a look and quote me for it.
6
Tulsa, OK
I had one that wouldn't work on mine. I pulled it off and found that the terminal had a hole burnt in it. A little grinding with a Dremel and some solder. 3 years, no problems.
