Car vibrating at high speed.
306
Detroit, MI
Guys, yesterday was the first day i took my car outa town in about 2months after i put my rims. Ok first was that the car and my steering wheel was vibrating when am on a high speed of about 70mph and so on. Also the car vibrates on little turns. I mean little turns. Any suggestion why this is happening? Is it Wheel balancing or what? Am so confused.
202
King of Prussia
start with the easy stuff ... then worry about the expensive stuff
- check the tire pressures... If yunning a low profile tire.. there could have been a few flat spots on the tire from sitting... sometimes corrected as the temp increases in the tire to the "proper" temp... they round out a bit
- check to see if any brake dust settled on the wheels inside... could throw off balance
- Check the torque specs on the wheels
- check to see if any wheel weights fell off - get the tires balanced
- Check the alignment - fix if necessary
- Thrust arm bushings, or other suspension components
