Check engine light
MikeO
6
Painesville, Ohio
the description of my fault code is throttle position sensor and fuel tank pressure sensor. I replaced the throttle position sensor with no luck so it sounds like the fuel tank pressure sensor might be the faulty part. The book shows it under the passenger side rear fender attached to the fuel expansion tank. Has anyone had to replace this sensor and if so how much of a problem was it getting it out?
Thanks, Mike...
