bigdavid1001 said:
yes the whole point of the CAI is to do just that. The "cold" air, relative to the rest of the engine bay greatly assists in combustion. something like every 10 degrees cool equail like a 30 percent increase in output. The heat shield keeps the filter separate from the rest of the surrounding area. This shield is what provides the cold air of the CAI.
A hole in your brake duct near the filter of a ram air tube is what provides the cold air.
The heat shield protects the intake from hot air from the engine compartment.
A true CAI should not need a heat shield. Its designed to be as far away from the engine as possible away from the warm air.
The cheap "short ram" intakes need a heat shield because they sit so close to the engine.
You can see in the picture below that my 8" K&N filter is not even visible because it is tucked down away from the engine. A heat shield wouln't hurt anything but it won't make that much of a difference. My filter sits right on top of a hole I cut in my brake duct to get OUTSIDE cool air to my filter.
