Feedback requested from the forum:
Began to get a whirring/grinding noise from the rear of my 1993 318IS with 123K miles and drove with it for about a month. Took it to my repair shop (had pretty good exp with them) they made two recommendations.
1) The rotors/pads were near 5% so recommended new rotors/pads. OK'd service but grinding noise was still there.
2) Further deteremined the rear driver side wheel bearing was shot. OK'd replacement.
After spending $740 on both services the grinding noise, while reduced, is still very prominent. Now I being fed a line that its also possible the differential is also shot but because of the wheel bearing noise it was impossible to have flagged this added defect.
What do you think? Incompentent tech? Guessing at a problem? Thinking of taking the car into a local BMW dealerhip, spending the $100 to confirm this diagnosis or to see if maybe the wheel bearing was not installed correctly.
If it truly is the differential I never would have spent the $740 for the brakes or the bearing as I cannot see sinking another $1000 for a new differential - would have simply driven the car to its last breath. Not a happy camper at all.
Any thoughts on other possible causes of this grinding noise prior to my scheduling the dealership appointment?
Thanks for any thoughts.
