I have had an ongoing probelm with the driver side power winodw. It usually starts with a slight grinding sound when the door is closed which initiates the "close with door shut feature". Eventually the motor will stop working with the window in the fully closed position. Tt seems like the motor and the winow gear get jammed, but can't be sure as you can't see it. I have already replaced the motor once, and it seemed fine for several months, but just started again. I have chceked the window adjustments according to the Bentley manual, and they seem fine. Any ideas?
