Flickering Climate Control lights
ryan9078
14
Manchester
Hi all,
I have the digital duel climate control fitted in my 96 328i
I recently fixed the problem were by it would shut down at random, and dim etc it was a failed cap on the power rails that fails to smooth the 12 volts as the voltage fluctuates during driving. However i still find that the blue (temp down) LEDs flicker. I dont however know where to look for the transistors that drive them are. I have little knowlege of this board other than the power line and regulator and wondered has anyone got a scimatic or had this problem.
Incidently if anyone has the Shuting down problem i have a detailed istruction doc. and a few capaitors left that i used to replace it with. [thumb]
MikeO
6
Painesville, Ohio
I had exactly the same problem. I carefully took the unit out and drop kicked it into the garbage can. It took three kicks but it finally went in. Then I went to my charge way to much dealer and got a rebuilt one. He happened to have a whole shelf full of them. Things been working great ever since.
Good luck, Mike... [thumb]
