Just the other day I noticed my fog lights didn't work. I checked and replaced the fuses (they were good but I put new ones in anyway) checked the bulbs with an external power supply and checked the fog light switch to make sure it works. All those things work... but the fog lights still don't turn on - no green indicator on the dash either. When I took the left fog light out it had water in it because of a bad seal, quite a lot actually. I'm thinking that maybe the relay is fried? Bavarian Autosport has the fog light relay in stock for $17 - should I just go ahead and buy it or is there anything else you guys can think of? Also, where is the fog light relay located? Is it in the fuse box or under the dash behind the glove compartment?
ok - Thanks!
ok - Thanks!
