Fuse relay charts? Anyone Know?
12
KANSAS
convertible wont go up! HELP>>>PLEASE!
Ijust bought a 1995 BMW 325I with 98,000 miles. And i messed up the convertible top by pulling the manual override lever, but im prety sure i got the motor reset. then the back would go up alittle bit, but then it quit working again is it possible i blew a relay? if so ineed a chart to know which one it is. I have checked the actual fuses, all appear to be good.
44
Louisville, KY
Component Location View Figure Not Available
Component ID K18363, Convertible Top Relay I (CLOSE)
Location In LH Side Of Luggage Compartment
_________________________________________________________________
Component ID K18364, Convertible Top Relay II (OPEN)
THERE ARE TWO SEPRATE RELAYS ON TO OPEN AND ONE TO CLOSE I HAVE ALSO INCLUDED THE LOCATION OF THE CONVERTABLE TOP CONTROL MODULE BELOW
Component Location View Figure 1
Component ID A96, Convertible Top Control Module
Location In Lower LH C-pillar Behind Side Panel
I HOPE THIS HELPS
ANDREW
12
KANSAS
ok i cant really decipher it but ok so i was expecting the relay to be in the front with the rest of the fuses, those big square ones. but its not, is that correct? so does this problem sound like a relay then? Because i tested and there was no power on the connection to the motor.So its before the convertible motor somewhere. Thanks for the reply.
44
Louisville, KY
WELL THE RELAYS ARE LOCATED IN THE LEFT HAND SIDE LUGGAGE COMPARTMENT (TRUNK)
AND THE CONVERTIBLE TOP MODULE IS LOCATED IN THE In Lower LH C-pillar Behind Side Panel AS PICTURED. I DIDNT FIND ANY FUSES LABLED CONVERTIBLE TOP BUT CHECK THEM ALL TO BE SAFE
12
KANSAS
Man, my radiator broke on my BMW! Now i have to fix that and my converible top. A new radiator is $146 which isnt bad but it still sucks. I just Wonder what the hell is wrong with the convertible top! I'm gonna take it to a dealership probably. Thanks for all your help.
44
Louisville, KY
mann hard times [bigcry]
I hope you get it all straightened out
