I'm having problems getting to these 4 (2 torx, 2 hex) bolts. I have the engine support off so the engine/tranny is leaning backwards the way that was reccomended.
Any hints? My friend and I (both fairly skilled mechanically) have messed around with wobble extensions for the past 2 hours.
I decided that half the extensions were very bad, harbor freight quality. I ran to sears and bought this...
-3 different sized wobble extensions (Have used these before, just needed MORE)
-3-piece Socket cap set - basically one end has the 3/8" end with the ball bearing that a socket wrench would have - and the other end (they are half an inch tall) is a 9/16-in hex head.
-9/16-in U-joint flex socket. Bascially its a U-joint but it has the 9/16" end so you dont have to use a socket AND then a U joint.
The problem I've had with u-joints that fit into the socket, is they tend to make the socket "curl off" the nut/bolt.
![Stick Out Tongue [:p] [:p]](/images/smilies/tongue.png)
