information center and sensor questions
8
Atlanta
Hey all. I just bought my 325 and the information center display is pretty scrambled and barely legible. Any ideas on replacing that and where to and how?
Also, I have an airbag light that stays illuminated for the first 3-5 minutes of driving and then extinguishes. Any ideas?
AND LAST, I have the ABS and traction control lights that come on together as a pair very occasionally. These can be reset by turning the car off and then re-starting.
Any suggestions and cost estimates would be greatly apprecited! Thanks!
Matt
Bad pixels in the display, most likely you will need to replace it.
Faulty airbag sensor? Has this car been in an accident?
When the ASC/DSC lights come on it indicates that the system is off. Has the tire size been altered from original? Could be a bad ABS sensor, do the brakes work properly? When you brake hard does the pedal pulsate
8
Atlanta
No accidents per carfax and inspection when i bought it. Tire size is original. Brakes work and feel good. It does not pulsate when braking hard. I haven't braked hard enough to skid and set off the anti-lock system if you are referring to an anti-lock pulsating.
Thanks!
