Inspection Bar at start-up...
323
Texas
What does this mean? the little bar with green then yellow then red...like an indication of someting?it says inspection, but i have no idea what this is...anyone help?
323
Texas
eek. i guess i need service then...its yellow. what kind of service? oil change? does this light automatically come on after so many miles? or is it really smart and knows when somethings wrong lol? thanks man!
323
Texas
so it could be an number of things? oh great...i dont exactly have any money right now to take in for nothing to be wrong. do they just check it out, or is there something that they definetly will do, and not just to rip me off? know how much it costs?
83
Calgary, Alberta
there are 2 inspection intervals. if you are unclear on which interval was carried out last then you should get inspection II done because it includes everything from inspection I.
inspection I:
change oil and filter
check trans fluid level (auto)
check engine components and hoses for leaks
check the drive belts
check the steering and suspension
check brake pad thickness (front and rear)
check brake hoses and lines
check and lubricate the throttle linkage
check parking brake
check exhaust and mountings
check seat belts
lubricate all locks and hinges
replace pollen filter
check headlight beam alignment
check windshield washer system
check engine management system
road test the vehicle
check wiper blades
reset service indicator
inspection II:
replace spark plugs
replace air filter
replace tranny fluid (auto)
replace diff. oil
check driveaxel boot condition
check parking brake shoes
addition work to be carried out every second inspection II:
change manual tranny oil
replace the fuel filter
check the clutch
323
Texas
well the dealer (not bmw) i bought it from said that he just serviced it, i even watched him replace th o2 sensor, but he must have not reset the light? i am mad, i dont want to pay a couple hundred bucks for nothing, but i dont want to reset the light and possibly overlook something[?|]
1,247
NY
If the dealer did everything, you can reset the light easily with no or little cost. When I got the car, I took it to the mechanic who checked everything I could think about, replaced the fuel filter, spark plugs and changed the oil. I didn't want the light to be there so I reset it myself. This is a pretty good DIY write up on resetting the oil and service lights. http://www.unofficialbmw.com/e36/electrical/e36_reset_service_lights.html You don't need to make that thing the guy uses, a regular wire will work just fine, at least that's what I used.
1,247
NY
#15
It depends on what e36 it is. The 325i you and I have, has one. It's right in the middle of the whole car, where the two exhaust pipes come together just for the sensor and then split again. I tried changing mine by myself but there isn't enough space. I got tired of it and went to a mechanic. The guy couldn't get to the sensor even with the special tool, he had to disconnect the exhaust from the headers to get to the sensor. Good thing I didn't bother getting the special tool.
