drkeng said:
I have the HS850 BT headset that works pretty well, so I don't have to hold my phone now. The voice dial works pretty well on it, usually within 1-2 tries.
Looking forward to using the steering wheel buttons to dial, not having the earpiece and integrating with the sound system.
I don't have nav, but just curious: Can you find a restaurant in the nav system and have it call the number with a voice command? My friend's Acura RL system does that.
Predicting 70 deg tomorrow!!
Could be top down! BTW, had to bring the car in for a squeak that ended up being the top--they had to re-lube it.
Regarding the NAV and restaurant dialing, the voice feature will activate the navigation and locate a restaurant either at your present location or at the destination (if you're using the guidance feature to get where you're going). Once the system finds the number it won't dial it without some physical intervention by you (the Acura implementation is better). However, I've got a workaround that I use. Once the guidance system finds and displays the restaurant, I tell the system to dial the number. So the interaction goes something like this:
Bry: [presses "talk" button on steering wheel then says...] "Restaurant at destination"
System: [locates restaurant list and displays alphabetically or by category on Nav display]
Bry: [turns dial to select desired restaurant... address and phone number are displayed... then Bry presses "talk" button again and says...] "Dial Number"
System: "Please speak the number"
Bry: [reads the number from the Nav display...] "415-555-1212"
System: "415-555-1212... continue?"
Bry: "Dial"
System: "Dialing"
It works pretty well. The tough part is choosing a restaurant from the long list of possibilities at the destination. ;-)
