I don't think I've ever posted a ride thread on here, and seeing as I've been a member for awhile now thought I may as well. I only read and contribute to the e30/e21 forum as that is where my interest lies, so those of you who are regulars here probably recognise my username, for the rest of you - hi.
My first e30 was a mint 1989 Euro ex Japan 320i that I lowered, converted to manual and tidied up real nice, but I wanted more. I wanted more power, I wanted, leather, I wanted a sunroof, I wanted cruise control, so...
In June I picked up this:
I then went through the process of stripping out the 320 in preparation for sale (remove springs and sounds basically) and began modding the 325. I sold the 320 in August for very close to what I was asking and finally had a chance to polish the 325 and put up some pics.
Original Specs when purchased: 1990 325i imported from South Africa
195000kms
Auto
Leather interior (BMW Recaros)
Cruise control
Longrange fuel tank
Sunroof
Sump guard
Front and rear sway bars
Maintenance sinced owned:
Cambelt, waterpump, camshaft seal.
Flush and replace coolant.
2x oil change (because I cracked the sump and had to do it again after the sump was repaired)
new plugs
new motor mounts
new gearbox mounts
new power steering rack
new tierod end LHS
new front wheel bearing LHS
new brake pads and machined rotors
dyed black parcel tray
a couple of days cutting and polishing to remove massive paint damage on bonnet (successfully)
replace countless bulbs and fix various little things like jerky windscreen wipers etc. Someone had got a vivid and blacked out the seatbelt warning light on the check panel!!!!!
Mods to date:
Manual conversion - Getrag 260 5spd with Luk Clutch and z3 1.9 shortshift
remove gay unsheilded pod filter and replace with stock airbox and k&n panel
Motorsport Bilstein shocks with supa low springs of unknown brand - blue but not dobis. sump guard is 85mm off the ground. Lowest chassis or suspension component is 110mm.
Alpine MP3 head unit powering JVC 6.5" rear two-ways and into Rebranded Caliber CA475+ 4ch amp
Infinity 6000CS front splits on two channels. Pioneer 12" TS-w306C single voice coil sub (600W RMS) on two bridged channels in custom ported box tuned to 38Hz.
Dynatron D7800 alarm dual immobilisers, keyless entry, and "presence sensor" (So i dont have to push the button to disarm the immobilisers - it knows the keys are in the car).
Blacked tails and front and side repeaters
17" momo rims running Dunlop SP 9000 DSST run-flats
Red instrument needles
Mods to come:
Euro plate
Exhaust
Body kit - probably mtech two sides and rear skirt, mtech I or II rear spoiler and is front lip - as these come available.
Paint - I want to go a deep black of some sort. I have priced this and it's definately a go once I have all the kit and get a few dollars together - I'm thinking mid to late next year.
This motor is getting on a bit so I don't want to spend alot on it. I'm going to maintain it until it gets tired or breaks and then I'll re-engine. No specific plans as of yet, but I'd like around 200HP if possible.
Anyway - enough of that - here are the pics.
Interior - yes it is actually that mint...
195000kms
Auto
Cruise control
Longrange fuel tank
Sunroof
Sump guard
new plugs
new motor mounts
new gearbox mounts
new tierod end LHS
Mods to date:
Mods to come:
Euro plate
Exhaust
