I joined this list in desperation. I've been restoring Jags, Porsches, and Austin-Healeys for decades, but can't crack this one. My '94 525i is boiling over. I have replaced the thermostat. No go. Radiator was replaced two years ago. Replaced the sending unit for electric fans. No go. No "cream" in the oil. Engine runs great. No white smoke. Coolant pump replaced two years ago. It does take quite a while (ten minutes or more) of highway driving before it boils (and with a warmup to correct temp before hitting the road).
But . . .
I do notice that the electric fans don't come on, even when the car is boiling over. Fans work great with a shunt at the end of the line with the ignition on, per factory manual (I did replace the sending unit). So, is coolant not circulating owing to 1) blocked radiator, despite relative youth, or 2) defective new thermostat? The lower hose never gets hot hot, just warm.
I tested the new thermostat (from a company that I'm sure many of you know well) and it opened only about 1/8 inch or less in boiling water.
So, the 64 thousand dollar question is: "Is it an idiosyncrasy of BMW thermostats to open only this amount, or should they pop open big-time like the ones I know and love from other makes?
I know; I need to check radiator cross flow, cooling system pressure, etc.
Thanks, Bill Runyan
But . . .
Thanks, Bill Runyan
