Paint Chip Repair
Tom
Staff member
8,346
13
Southwest
Despite the technological advances in paint over the last hundred years, an automobile's exterior comes under heavy assault the instant the car rolls off the production line. Door dings, bird droppings, corrosive rain, winter road salt and ocean fog all take their toll on that thin layer of color that protects your vehicle's steel body from the elements. Rock chips are especially damaging, as unlike contaminants that slowly eat away at the paint, rock chips cut all the way down to bare metal without prior warning. That allows moist air immediate access and surface rust soon follows. Worse yet, the rust can spread like a cancer beneath previously undamaged paint, so it's best to fix the damage and seal the hole as quickly as possible.
Clean the Injury
Begin by thoroughly cleaning the repair area with a standard car detergent and water solution. Rinse all soap residue from the area and allow to dry completely. Using a fiberglass pencil (available at most auto parts stores in the paint and body department), carefully remove rust and loose paint from the chipped area. Fiberglass dust is a severe irritant, so be sure to wash your hands when finished and don't breathe or allow the dust to contact your eyes while working. Hopefully the chip is fresh and rust hasn't had a chance to take hold, but if the metal has been exposed to the elements for some time, it may be necessary to use a tiny piece of 800-grit sandpaper to remove all traces of rust from the area.
Fill the Crater
Determine the manufacturer's color code for your vehicle (check owner's manual to find out where the data plate is located) and obtain a small bottle of touch-up paint from your local dealer or auto parts store. Brush thin coats of paint across the repair area, allowing each coat to fully dry before applying the next. If the chip is very small, you can use a sliver of thin cardboard to dab the paint into the hole. Fill in the chipped area one layer at a time until the new paint is higher than the surrounding factory paint. Allow at least 24 hours for the final coat of paint to harden.
Blend the Repair
Starting with a small piece of 1500-grit wet/dry sandpaper wrapped around a small foam-rubber sanding block, slowly sand down the raised touch-up paint. Dip the sandpaper into a container of water regularly to rinse removed paint from the abrasive. Try to sand only the touch-up paint, as the factory paint surrounding the chip is quite thin and will not handle very much sanding. As the touch-up paint nears the same height as the factory paint, change to 2000-grit wet-dry paper for final sanding. The paint in the area will take on a matte appearance, which is then polished to a glossy finish using a small amount of rubbing compound on a clean cloth. Follow with your usual auto wax or polish to give the fresh paint a protective coating. The quality of the repair will depend on your work and how well the touch-up paint matches your factory paint. But regardless of results, the ugly crater will be filled and your vehicle's sheetmetal will be protected from additional exposure. And if the repair goes well, no one will notice that the chip was ever there!
Text Source
Thanks tom, I'll definitely and unfortunately get my use out of this. On the note of paint chips, anyone here use Lanka's anti blob stuff? Bavauto sells their kit.
61
Simi Valley, CA
When you put the touch up paint on the car, cover with a small piece of tape. Let it dry for an hour or so, then remove the tape and let the touch up thoroughly dry. Repeat until the paint is level. Then very lightly sand and buff out. This works great on small chips and scratches.
B2Blain
Kailua, Hawaii
Ok, very interesting DIY. I usually just apply the touch up paint. I didn't know you could make it look like new.
Here is what I am afraid of - sanding too much. What is a typical application? How many coats? Also, how do you insure you don't sand off the wrong paint? Won't you inevitably sand of a lot of the clearcoat on metallic paints?
Thanks!
405
Los Angeles, CA
a friend of mine had his 04 lexus sc serviced recently, and according to him for about $1000 - $1500 (depending on the damage), they basically go thru and fix and touch-up all the minor nicks, scratches, chips, and/ or dings on your car in just a day or two. and, he was very happy w/ the results.
has anyone else done this before and how was the pricing/ service?
i really like the DIY info. however, when i try to touch-up those little things, it's more like a crime of auto-body mutilation. plus, i just don't have the time to deal w/ it to do it right. it would be so much easier to let the pros handle it.
1,035
Maryland
clear_bumper said:
if your sick of door edge chips and you hate always doing touch ups, then stop!!! take a look at this product. it a great protection tool for your ride. any model it doesnt matter it looks good on all of them WWW.CLEARBUMPER.COM
I'm shocked no admin did anything about this apparent spam? ...Usually you guys are on spam like sh!t on velcro. I guess maybe you only delete spam threads and not spam replies. eh.
