RE: Steering Vibration - Tried Everything
Hi Guys:
I am at my wit's end.
I bought a 1993 318is about two months ago. I knew the car needed some front end work, so I bought it anyways.
There was a bad steering wheel shake above 40 MPH +. I took the care to a local import shop and they had the both lower control arms, both tied rods and the bushings replaced as they were worn and this appeared to be the issue.
Great, problem solved right - not even close. The repair shop then stated that the front tires were out of round, so I bought two new tires (225/50/16's) - still the same problem. This repair shop states that the front end is perfect so they cannot isolate why the steering wheel shaking persists.
I have tried a road force balance on all four tires, moved the back rims to the front to see if there was a wheel rim issue - still the same problem.
In desperation, I tried replacing the front rotors in the small hope that perhaps they were not balanced - same problem (AHH!).
I have spend almost 1500$ and I am stuck with the same problem that makes the car almost unbearable.
The only thing I have not yet tried is putting two completely new rims/tires up front to see if the problem abates. The current rims are 16" M3 knocks that were on the cardwhen I bought it, so maybe there could be some type of issue with this rim brand just not seating correctly against the wheel housing? I really don't want to plunk another couple of hundred down on a pipe dream solution.
As anyone had any simliar expierences on their 318 and what your soultion was? I am really at the end of my rope and I cannot continue to throw money away - but what option do I have?
Thank you for any suggestions.
Hi Guys:
![Roll Eyes (Sarcastic) [rolleyes] [rolleyes]](/images/smilies/rolleyes.png)
