Hi All
In the process of trying to get better bass then what I get if i just put a couple of boxed 10" subs in the back and have decided that I am going to remove the rear deck and make a custom one which will house the two 10 drivers in the middle and a pair of 6X9 (one on each end for the mids/highs). I will be cutting two holes in the sheet metal work of the deck for the subs and also resahping the original OEM hole of the 6X9 to accomodate better units. I find that these cars are built so well that all the low end bass is lost if you put an enclosure in the trunk and have the rear seats up.
Therefore does anyone have a quick guide on the best/right way to remove the rear deck?
Also has anyone done this before?
Thanks guys
Thanks guys
