my rear shocks are going bad on my 98 m3 if i replace them with some blistin sport shocks should i replace the springs also or is that unnessasary, speaking from a matnence stand point not profromance. Thanks
replace the springs... if you don't and the spprings get saggy you probably don't want to repalce them later since while doing the shocks you'll already be in there. Might as well get them done.
They should be fine, replace the shocks and that should suffice, springs should last well beyond 150k. My 733i had factory springs that lasted well beyond 250k, granted I did replace the shocks once in that time!
also it leans a lil to the left, it hardly noticable unless you really look at it for a while, could that be a sagging spring or have somthing to do with the bad shocks, OR somthing worse :X..
