If the 318 is the same as the 325, there is a rubber O-ring that seals the pump to the block. It is a tight fit, and gets "stuck" over the years. You just need to keep pulling. Wiggling up/down/left/right while pulling will help. A few taps with a block of wood may help to break the seal.
