actually it's above your glovebox.
open the glovebox up, and feel for two tabs on each side on top. twist both 90 degrees, and the fusebox will drop down.
there is a card in there that has what fuse is connected to what component so you can troubleshoot what fuse might be blown. the card also shows the location of the spare fuses, iirc they are the ones plugged in horizontally. there's a little tong in there to take the fuse out also. good luck
