Hello everybody, this being my first post I think it is only right to get the drinks in, so this round is on me.
Ok now my problem.
I have just purchased a 1996 318i touring with a intermitant fault.
The car will drive fine at all engine speeds then all of a sudden it sort of dies for a few seconds. It seemed to do it more when the engine was put under greater load,eg going up a hill, but it'll also do it when setting off from a stand still. It just feels like you have taken your foot of the gas pedel. There is no pattern to when it will do it, it doesn't happen at every hill or at every set of lights but it will happen 2-3 times in a 20-30 mile journey. Even if you dip the clutch and try to rev the engine it makes no difference to the engine speed.
The rubber boot that connects the air flow meter to the throttle housing was split, so I purchased a new one, which seamed to help but didn't cure the problem.
The engine management light isn't on, but then again, I dont think it works because it doesnt light up with just the ignition on and the engine not running. I dont know how to check for fault codes either with this being my very first BMW, but I'm sure I can find a post about them somewhere.
Also I dont know if this is related to the same problem, but when I come to a stop at traffic lights the engine continues to rev to about 1200rpm then after about 5 seconds it will drop down to a steady 950rpm.
Hope someone can help.
Thanks
Smiffi
Ok now my problem.
Thanks
Smiffi
