A few weeks ago I lost my timing belt.  Sent head off for re-build, replaced water pump, new gasket kit, new head bolts, new belts.  Using the Bently manual, I re-assymbled the engine and surprisingly had it running (very rough idle) as I was checking for leaks I found about 4 quarts of oil on the garage floor!!!  I shut the engine off ASAP, now I can't find the leak.
Did I miss a major step in the rebuild or could my block be cracked?
Scratching my head in Orlando!
Jeff
Jeff
