J to the O said:
Njmurvin
Thanks again for replying back!!!!!!!!!!
I opened up the steering column and I was confused about the ignition switch module. I saw a module that looked like a relay that was white with 8 wires coming out of it. I was not able to loosen it out. I was wondering if you could give me that web site with the instructions and the p/n number of the iginition switch so I can double check. If you could give me a brief description of the repair proceedures, I would appreciate very much.
Thanks again,
J to the O
If you opened the steering column, you did most of the work. I looked for the website and couldn't find it again. It was something I tripped over . . . in searching for instructions and I can't seem to retrace my steps. However, the job isn't difficult once you get the steering column open.
I don't have the part number for the switch. Go to the dealer and describe it as the "electrical part" of the ignition switch. It should cost around $60. It's kind of cylindrical in shape and mostly black with a white translucent cover over the electrical contacts.
Open the steering column by removing the top and bottom screws. Lower the column and telescope it out as far as you can to get the best access. You need to remove both top and bottom covers completely by unclipping from the leather. I tried to do this without removing the top one and couldn't gain access to the top torx screw with it on. The covers turned out to be very easy to R&R.
On the left of the column, you'll see the switch. It has a white rectangular wire plug (which I think is what you saw). You need to pull up a little locking tab on the side of the plug in order to unplug it. There are two torx screws that hold a black plastic bracket that has to come loose, but not out. The top one is a PITA to get to. You might think you can do the job without loosening this, but I couldn't. The bottom one was easy. I had to use a curved allen wrench on the top one. This was the second hardest part of the job for me (the first being the opening of the steering column).
You'll also find two very small red painted set screws. The paint covers the screw heads. These are set screws that lock the switch from moving. They need to be loosened as well. Scrape the paint off first to reveal the screw slot. Then use a small jeweler's screwdriver to loosen - but not remove. A couple of turns is all you need.
The switch should now pull out. One end of the switch engages with the end of the key cylinder. Note the position of the white dial on the end of the switch you remove. Use a slotted screwdriver to position the dial in the same position of the new switch before you install it. It will be obvious when you see it.
Now reverse the above procedure and you should be good to go.
Good luck.
