amp power wire
hbrett
7
Florida
I am trying to install a new amp in my 96 318. I cant find anywhere to run the power cord from the battery to the amp. Any suggestions. I found no holes through the firewall or holes already there and the bottom is flat because of the unibody style and no place to run it there. Thanks for any help u can give.
[email protected]
323
Texas
huh. most e36 batteries are in the trunk. look and see if there is a pre-run cable to where the battery would be in the trunk, and if there is just run your wire from it.
as far as running a cable through the cabin, let me look and i'll post when i find a route. i have a 95 325i so they should be the same almost if not exactly.
Well, I read somewhere that 328s have the battery under the hood so that wasn't a surprise. When I was running an power wire for my HU, I ran it right next to the wire that goes from the battery in the trunk. Since I wanted to make it look even better and come in the the fuse box, like it was done at the factory, I searched high and low for a good hole in the fire wall and all I can say is that there simply isn't one, at least one I found.
You can try finding the hole that other e36s used to get under the hood with the battery wire. To find it, you would have to remove the main carpet that comes up to where the passenger's feet would be. It is pretty high up, just close to the end of the carpet, but I would think that it is sealed completely.
You got a real interesting issue there. I know you can't run it with other wires because they are sealed completely with the rubber gormet and there is no way of getting around that with a coat hanger without ripping it. Maybe you can get by the fire wall where the AC lines are or where the system gets air from the outside. I don't know, sorry man, I can't help you there except for saying that you will either have to be very creative or drill a hole in the fire wall.
