Brake light on after brakes replaced
St Helens, England
Hi,
I noticed a slight squealing in my brakes, soon after the brake warning light came on. So i took it to the garage and got the brakes done. However 2 days after the brake light is still coming on every now and then. I checked the brake fluid level and its at the max. Could it just be a faulty sensor? Also the brakes seem to be a little un responsive, ie. i have to put my foot right down for it to stop, as before if i did that it would just jump to a stop. Is this because the brakes havent not bedded in yet?
Thanks
Cat
[driving]
VANCE
Active Member
853
ATLANTA, GA
you did'nt mention if you replaced the sensor. you should whenever you change you pads.
also you could have some air in the lines from not properly bleeding them.
signal hill ca
it the brakes i bet because you say youve got full fluid but its still hard to ge them to stop. brakes shouldnt really have to seat in right when you service brake pads you have to bleed the system most times,.,.,. but it sounds to me like air in the lines
