Coolant Sensor
77
Glendale, CA
Every time I shut off my car the computer says "check coolant level," but my coolant level is fine, so I think I need a new sensor. Does anyone know how much a new coolant sensor would be for a 1997 328is and what triggers the coolant sensor to malfunction like mine is doing? Thanks for any help.
109
Columbus, Ohio
i cant help u much...but since ur on this subject....i always get the check coolant level message when its cold outside.....not sure why....i dont see it when its warm
29
Ireland
Had the same problem, find where the coolant topup cover is. at the bottom of this side of the rad area there is a sensor plugged in (coolant level sensor) its a bit awkward to get at, might wanna wait till engines cold. Unplug the sensor and clean the pins (i used my finger but u might wanna use somethin better) plug it back in and hey presto problem solved. Due to where the sensor is mounted dirt inevitably gets in and screws with it. If this doesn work, besides being shocked u may need a new sensor. Like i said though this solved mine and peoples other peoples problem hope it works for u
