Abdoman, I use the lever to shift while turning, instead of the paddles ... it's easier since the paddles move with the steering. I had an M3 6-speed before I got the smg. I think control is about the same. You gear up and gear down the same, just a lot (a whole lot) faster. As a result, when being challenge, the other guy can't shift fast enough to keep up with you. Trust me, if you drive an smg, especially at high speeds (drivelogic 5 and above, in smg mode, and sport button activated), you'll be amazed.
