Door Mechanisms
stimmy
19
Maine
I bought my 92 318is a few months ago and since then the door mechanisms have been a bit... german. You basically have to pull up, hard, then out, to open the doors, both sides. It's a coupe, so there're only two of course. Has anyone had similar experience or have tips on fixing?
2,195
Houston
try adjusting the little contraption thats on the body of the car, the place where the door latches on to...there should be 2 inverted torx(i think thats the name) bolts holding it on...ill have a picture later today.
2,195
Houston
first try spraying some wd-40 on there and see if it helps...if it doesn't then use this to help you out...
loosen the bolts in red and then slightly move everything, retighten the bolts and close the door...btw, thats a pic of the passenger side.
247
S.E. CT.
Manuel,
I just "hit" because curious about the post. You are so helpful! Nice to help a guy out!
-M
No need to reply, just wish I could help once in awhile!
Glad to have you on our side!
PuShAkOv
2000 Post Club
2,523
Cleveland, OHIO
I had that with my door, I thought something was wrong with it so I went to the dealer, they just sprayed some stuff on the handle and it was much better [:D]
162
Northwood, NH
if that doesnt work, pop off your door panel and re-adjust the latch mechanism. You might not be completely disengaging it, causing you to need to "lift" the door open.
stimmy
19
Maine
I'm pretty sure that kev415 had the right idea, and I'll try to do this tomorrow. Thanks a lot, and I'll post the results.
