Hi all...
I'm in the process of trying to replace the center support bearing on my 1987 BMW 325 (base), auto trans. Man those bolts are tight!!!
My I've got access to the driveshaft and have gotten the front u-joint bolts (on the transmission side) loose (I was surprised there is no flex-disk, guibo, on this car), but the ones on the back end are TIGHT!!!! bloody knuckles, cussing, etc, won't help.
My question is, can I replace the bearing without removing the back half of the driveshaft? if remove the front and seperate the two halves, will the bearing come off with the front half? or if not, can I do the replacement under the car? I've heard that sometimes you have to have the bearing pressed onto the shaft, and that would require pulling it and taking it into the shop...
Anybody done this???
Thanks..
Thanks..
![Big Grin [:D] [:D]](/images/smilies/biggrin.png)
