I have a 1986 325i fitted with a Motronic fuel system.
At tickover, when warm, the idle speed fluctuates between 500 and 900 rev/min.
I have tested the Idle Air Stabiliser Valve as described in the manual using an ohmmeter and it is OK.
On testing the three cable plug connected to the stabiliser valve I have 12 volts at the centre cable and 10 volts when connecting between centre cable and one outer cable. When connecting between centre cable and remaining outer cable I have no reading at all.
I cannot find anything regarding this valve or its plug on the Motronic System Wiring Diagram that I have.
Can anyone tell me what these three cables connect to and what might be the reason for the erratic idle speed.
