Hello all, I'm new to the forums. My name is Nick, I live in Charleston SC. I will be purchasing a 88 325i convertible, automatic for $4,500. It's in very good condition with 119,000 mi.
Odometer recently broke, found out how to fix that here. Current owner has had the car for 2 years and has only put about 1,000 mi on it.
I was told the previous owner was a BMW mechanic and did some mechanical repairs, replaced the head, no cosmetic fixing. Current owner had the interior reupholstered and a new rag top installed.
Right rear aft window wont roll down. When you press the button to roll it down, I don't hear anything, but I notice the interior lights get dimmer. My guess is that the motor is shot. Am I correct?
The owner allowed me to take the car today for a few hours to put her up on a lift and check her out underneath. Well, unfortunately everything is closed today (sunday, bible belt) so I drove the car on two wheels on top of a curb and crawled under her.
There seems to be a minor oil leak from the pan. Didn't look very bad to me. Some small chunks missing from what I believe is the catalytic converter due to rust. Noticed some build up of dust/grease probably due to a minor hydraulic leak on the aft left brake. Front right strut looked just a tiny bit wet, didn't look bad. The hood strut is shot, found one of those, there cheap. Paint job is excellent, so is the interior. Rear right trim on the bumper is coming off a bit, nothing some sealant cant fix. Tried to put the top down today but couldn't figure out how to open the aft section.
Didn't really notice anything else underneath. No frame damage or anything like that. Nothing really jumped out at me. The engine compartment looks to be in good shape. Again nothing really jumped out at me.
Read a post somewhere on here about making sure to replace the timing belt every 20,000 mi? I know how imperative it is to make sure those get changed. I had a 89 Nissan 300ZX timing belt go out on me in Japan. Junked the car cause I didn't get around to fixing it quick enough before I left Japan. That sucked.
Is there any way to check the condition of the timing belt?
I have probably driven the car for a total of an hour and a half. Took her on the freeway and everything. Didn't notice anything particularly weird. Cruise control works, engine sounds good. She feels good. Did notice a quite low whining. I could only hear it around 10-20 MPH, above those speeds the wind was too loud to hear it. Wheel bearings?
Is there anything else I should check for? Is there anything I should have the owner do besides a oil change, transmission fluid change, and tune up before purchase?
Thank you all in advance!
