The MID in my car has some broken crystals and is a fairly low-end one, anyway. This doesn't really matter to me, but it did raise a number of questions in my mind:
a) Can you replace a more functional one for a less? Are the connectors the same? If so, is this expensive?
b) Has anyone worked on a solution to transfer the data received on the connected to a PCI/ISA card for a computer? I assume this would take some soldering and all, but could it be done?
c) Could data be drawn directly from the ECM, giving a wider array of possible data?
Thanks!
Thanks!
