Howdy! and welcome!
'95 M3 Specs
Weight
Unladen 3175 lbs
Max.permissible 4255 lbs
Permitted load 1080 lbs
Permitted axle load front/rear 2007/2403 lbs
Permitted roof load 165 lbs
Engine
Cylinders/valves in-line 6/24
Capacity liters 3.0
Bore/stroke inch 3.39/3.38
Nominal output/rpm hp 240/6000
Max. torque/rpm lb-ft/min 225/4250
Compression ratio/prem.unleaded fuel :1 10.5/min. 91 octane
Transmission
Standard gear ratios I/II/III/IV/V/R 4.20/2.49/1.66/1.24/1.00/3.89
Final drive ratio 3.15
Automatic gear ratios I/II/III/IV/V/R 3.67/2.00/1.41/1.00/0.74/4.10
Final drive ratio 3.23
Performance
Drag coefficient Cd .32
Top speed mph 145+
Acceleration sec 6.1
1/4 mile sec 14.5
Fuel Consumption
City mpg 19
Highway mpg 27
Fuel tank capacity U.S. gal 17.2
Wheels
Tire dimensions 235/40 ZR 17
Wheel dimensions 7.5J x 17
Material Light alloy
Electrical System
Battery capacity Amp-hours 75
Alternator output Amp/Watts 80/1120
