That or also when the work was being done on your car, they most likely diconnected the battery. In some cases diconnecting the battery will reset lights. It has done it on my car before. What will most likely happen is your check engine light will come back on in a short period of time, I would say after you have drivin the car for roughly 10-15miles. I have bad precat sensors, and I have the peake r5 reset tool, and whenever i turn off the light it comes back on after I drive about 10-15miles. Have you drivin the car at all since it has been worked on? Cuz if you have just started the car than the light will not come on untill the car has been drivin, because 02 sensors work on timed pattern..........I can't explain it, but your car will scan everything and it will do it in sequence, and when it gets to the o2 sensor after it has warmed up and is giving readings than it will most likely report back a bad sensor. It just takes the sequence a little time to scan and re-scan cuz it does it the whole time the car is on. It just than when you are driving it accelerates the use of the o2 sensor, and gives better readings, not when the car just sits and idle's. Hope this helped some.
Patrick
