Like many other E30 owners, I have no working speedometer in my car. It hadnt worked in about 2 years, until recently it jumped into place and worked for about 5 seconds before quitting again. I have my instrument cluster out and the speedo off the main cluster part. I notice that the gears are in tough shape, but dont understand why it would work a little bit and then stop because of gears, and am thinking more of an electrical/wiring fault. I was fine w/o the speedo for awhile, because I could tell speed from the tach reading, but now the tach isnt functioning either. I was coasting into a town and glanced at the gauges when I noticed an RPM readout of about 4500, which I knew wasnt right. Then the tach needle started jumping around before settling at "0." The fuel gauge works sometimes, but usually reads a full tank even if it is empty. The temp gauge is dead. When disconnecting the plugs in the rear of the cluster, there are only 2 connectors that plug in, but 4 plug-ins at the rear. Also, about the same time the tach went my radio started cutting out. Maybe they share a ground connector of some sort that is coming loose...anyway very frustrating to have so many electrical problems, and no working instruments or radio. help me!! ![Idea! [idea] [idea]](/images/smilies/icon_smile_idea.gif)
