Okay, this is probably a dumb question.
My 05 330CIC has different sized tires on the front and rear. Also, the tires are directional. So... how do you rotate these tires? You can't do the usual diagonal swap because then the wrong sizes end up on the front and rear. You can't swap left with right because then the tires are spinning in the wrong direction. So... do you just never rotate the tires?
It never occurred to me that you wouldn't rotate the tires. AND... I was surprised when I found out that I had different sized tires on the front vs. rear. Can't really tell the difference at all just looking at them.
