wileycoyote said:
			And how would that save gas?  With a manual transmission, if you leave the car in gear and take your foot off the gas, you will get better gas mileage than if you put it in neutral and coasted.  Why?  Because in neutral, the fuel is required to idle the engine, in gear the injectors can shut off completely while the movement of the car keeps the engine "running".
	but do the injectors actually shut off? i doubt it. the friction would be too big without ignition compared to at least a minimum rate of fuel being injected.
why i think so: take a car at full stop. pop into neutral and rev it up to 5000 rpm. then
A) just switch the car off (which also stops injection
![Hi Hi    [hihi] [hihi]](/images/smilies/icon_smile_hihi.gif) )
)B) just step of the gaz.
result at a) is that the engine goes off instantly and the needle can't even follow the drop of the revs. with b) the revs drop slowly to idle. of course, the movement and it's energy will keep the engine from stoping instantly, but it will still go significatly fast. and it doesn't. my idea at least and i never thought about so i just constructed it. what do others think or know?
		![Thumbs Up    [thumb] [thumb]](/images/smilies/icon_smile_thumb.gif)
		![Bang Head    [?|] [?|]](/images/smilies/icon_smile_banghead.gif) ... though I wish it were a manual.
