Hi guys!
As some of you know, I have a '97 328i and have two years trying to solve a low end (<1500 rpm) engine hesitation. With the A/C off and no hills, this phenomena stays for three seconds or less and it's not a heavy problem but if the A/C is on and ther is a hill the lack of power is really very uncomfortable.
I have changed almost all power related parts, spark plugs, gas filter, air filter, fuel pump, had cleaned the injectors, changed the ign coil resistors (1K), and the problem remains.
I'm suspecting the problem can be VANOS related, it's the only one part I never tryed. As I understand the VANOS mechanical control has an electrical solenoid driven by the engine ECU and an oil pressure operated piston, so one of this two things can be the cause for the problem, I HOPE SO.
I'll appreciate any comment or experience with similar power loss problems that prevents me to buy a new VANOS valve only to discover that this wasn't the problem.
Thanks in advance
GUSTAVO
Thanks in advance
GUSTAVO
