Want to raise my ride. Coilovers or Springs?
4,412
Wayzata, MN
well, i'm guessing that your wheels, if they are from a 5er, have like a 30something or less mm offset, the spacer would make up for that offset difference (i think e36's can't go below 38 or 41mm) and then you'd have almost no rub.
I still don't get it. See the problem is that the wheel sticks out so much on the inside. Causing it to rub against the fender. If i put spacers, will it not stick it out more? Or maybe i don't know what spacers are. Help me. here's a pic of the wheel. it's the 17x7.5 one. am not sure what my offset is.
4,412
Wayzata, MN
do you have the 21mm or 45mm offset? stock for an e36 i think is 46mm, so the 45's should be fine. i think i misunderstood your request, doesn't sound like spacers would do the trick. but to tell you the truth i've never used spacers, and dont' understand all of their applications.
3,420
Metuchen NJ
yes u can roll and pull your fenders, about 35-50 per wheel.
they heat the paint, to prevent cracking then roll a machine
against the fender to stretch it out and pull it up a little
worked for me to stop rubbing. =]
Tom
Staff Team
8,351
13
Southwest
#14
Re: Just a suggestion . . . .
SKycity_BMW said:
Have you thought about rolling your fenders?
Skycity_BMW
I agree with what he said, most tire shops can do this or refer you to someone that can. I will take about an hour to do.
