Will an 18 x 8.5 with 35mm rims rub ?
4,412
Wayzata, MN
35mm is too low, i think your are not supposed to go below 38 or 40 w/ e36's, though spacers are an option, what aspect ratio tire are you going to run? i assume with an 8.5" run what? a 235? i'm not sure ify ou could squeeze a 245 on that size wheel, but i yeah....
frolf i don't understand your message. Will it rub against the fenders or not. I don't have much time.
19
Maryland
Hey guys,
My 18x8.5 Rondell's are 38mm o/s, w/ 245/40 and with the car lowered 1.4"/1" they rubbed over bumps or w/ passengers, i had a local tire shop use a rubber spacer on each rear spring and the problem was better. I found http://www.miamitireoutlet.com and the Hankook Veentus K104 245/35 ZR-18 for 132.45 eaach, Pepbnoys matched it. NO RUBBING
