I checked out tirerack, but they don't have the BBS wheels I like (the "CH" wheels).
A couple questions:
1. What can I realistically expect to get for the stock 17" wheels from a x3 2.5i... just the wheels, no tires.
There is a set on e-Bay right now for $800 starting bid (don't know if there is a reserve). Price includes the tires.
2. What does the offset refer to and can any offset be used as long as the bolt pattern is 5/120? What is the difference between an offset of 35 vs 38?
The offset refers to how far, off of centerline, the mounting bolts are located. So, if you go with a wheel that has a lower offset, the wheelbase will be increased. Decreasing the offset too much may create rubbing problems on the rear (if you bottom out). Not sure if it will create steering issues on the front.
3. What width can the wheels be? When looking at the CH I see 19" wheels with 8.5 and 9.5. Would either work?
Depends on the desired tire width.
I should be picking my x3 up in a couple hours!
Thanks!
Jeff
