well all i know is that its not a clean swap. the engine will be quite a bit heavier than your stock engine, and none of the mounts will line up, motor mounts, ac compressor mounts, all that jazz.
as for gear box, if i had the ratio's in front of me i could tell you flat out, but it seems only fair that they'd all be too high for your new motor.
keep in mind i am no master mechanic, though i strive to be, so hopefully someone who has attempted this will chime in.
