It's a moisture vent
It's there to vent moisture in the air and keep it from condensing on the lens.
Plug it, remove it or keep it from pointing down, and your lens will fogg up inside if you use your high beams.
The lens isn't completely sealed, and the little rubber tube allows the hot moist air to escape, (that's why it's at the top of the lens)
HTH
